Sponsored by:
Sponsored by: DashLynx
351W Swap
Old 08-17-2003, 02:20 AM
OmegA //408
OmegA //408's Avatar
Default 351W Swap
Hello. I am new here, and since there is no Windsor page, I figured this would be the best place for this. </P>
So hereI go....</P>
...I am planning a v6 to 351w swap, andI was wondering if the front accesories from a 302 would work for the 351, because as far asI know the 351 is a 302 with a raised deck. So, I was wondering if they would work. </P>
...I also want to do a 408 stroker kit, wouldI have to notch the block?</P>
...Nitrous or Blower??</P>
...Would a T5 hold up to to 408 Inches of Pain?</P>
...Carb or fuel injected?</P>
For the actual swap, the motor and tranny, i am looking to spend 3-5k, think this could be done?? Thanks for any help youse guys can offer!!</P>
&lt;The OmegA maN&gt;</P>
</P>
OmegA //408 is offline
Old 08-17-2003, 02:53 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
Default 351W Swap
The first two, I can not answer, not a ford fanatic when it comes to tech.
Nitrous first, blower if you have the cash and build your motor (you'd better keep the nitrous on there too!). It's cheaper and gives the same friggin gains....
T5, like I said, not for Techie.
FUEL INJECTED!!!
5k for a motor swap is easily done, assuming free labor (you do it all)
jeep45238 is offline
Old 08-17-2003, 04:58 PM
Buzzstang
Buzzstang's Avatar
Default 351W Swap
YES IT WILL ALL WORK. MARCH MAKES SOME NICE BRACKETRIE THAT LOOSES SOME WEIGH AND LOOKS COOL. IT SHOULD SET RIGHT DOWN IN THERE JUST MAKES SURE THAT YOU HAVE THE RIGHT OIL PUMP AND PAN. THEN HEADERS ARE ANOTHER FACTOR. PUT ELECTIRC FANS UP FRONT. ONE OUT OF A 99 MERCURY MYSTIQUE WILL WORK. THE TRANNY WILL HOLD UP TO EVERY DAY DRIVING BUT WHEN YOU MASH IT DOWN IT WILL PROUBALY WEAR OUT QUICK OR JUST COME APART. THE TRANNYS ONLY GOOD FOR TORQUE BELOW SAFELY 250 FT LBS. GO WITH A TREMEC.
Buzzstang is offline
Old 08-17-2003, 07:04 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default 351W Swap
Originally Posted by OmegA //408
For the actual swap, the motor and tranny, i am looking to spend 3-5k, think this could be done?? Thanks for any help youse guys can offer!!</p>
&lt;The OmegA maN&gt;</p>
</p>
No way in hell. You'll pay close to or more than 3k just for the motor. If you high miles on the T5, you'll need a better tranny, you'll need to do a rear-end swap, and countless suspension mods if you plan on ever hooking up, and you'll have to do something about feeding that 351w the extra fuel...
Dan04COBRA is offline
Old 08-18-2003, 06:20 AM
horatio102
horatio102's Avatar
Default 351W Swap
Forget the 351, drop in a 460. And screw the fuel injection, go with a carb. Sure it won't be as nice on cold mornings, but you won't have to fight with tuning it. Any dyno shop could dial it in.
horatio102 is offline
Old 08-18-2003, 07:55 AM
n2o44
n2o44's Avatar
Default 351W Swap
frpp does make a braket kit to accept the stock 302 serp belt ,notch the block yes most 351 strokers at about 377 iches ive seen some notching ,i would say most likely youll be grinding. i say turbo <IMG src=smileys/smiley2.gif border="0">, your gonna need a new trans if you can build one your self i seen some people that sell kits to make your t5 handle bout 600 i seen recently in a mag for about 1k in parts , but theres other places . and i would stick with FI. also i pretty sure your v6 k member will not fit any v8 , the older 4 cly stangs were ok not the 6 . be sure thou .
n2o44 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: 351W Swap
