Ford Techs!!! Please Help
I have to replace my Drivers side mirror and I'm not sure how to go about it?
Do I need to take off the Mach speaker to gain access to the triangle piece where it mounts? If yes how do you remove the speaker without breaking it? Or is there another way?
RE: Ford Techs!!! Please Help
its really easy... i did the same thing to my car but it was on the passanger side.... u just take the mesh cover thing off the of speaker... then there is a screw you will see... u need to take that off... u also need to take the entire door panel off from whatever side u screwd up... its really not very hard. screw around and ull figure it out.. just be careful not to break anything by mistake
ORIGINAL: GT1999
do you happen to have pics of the mirror's wiring harness? I but a Dr side off of e-bay and down is right. The seller thinks it is my car. I think it is his mirror. I have (in order) Yellow, Blue, Red and the mirror has the last 2 switched. Also, what year is your car (in case it makes a difference). Thanks for any help.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
09-02-2015 07:54 AM
