hey whats up every1 i was just wondering if sumone could help me out. i just recently put a 351w flat tap motor in my 88 stang, its bored .30 over, trickflow "R" series intake manifold, msd pro billet dist.,70mm TB, mac cold air intake, full exhaust, mac 1 3/4 long tubes, 24 lb injectors, mallory adj. fuel regulator, 190 lph fuel pump, and i just got a set of avenger cylinder heads with 2.02/1.6 valves with 1.6 ratio roller rockers
58cc and 205cc intake runners. could anyone tell me how much HP i should be expecting. and possible 1/4 mile times. i also have 3:73 gears, steeda tri ax shifter and a tremec t5 trans. thanks.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
88 gt, 351w (.30) dished pistons, trickflow "R" series upper and lower intake, Canfield avenger cylinder heads, 24# injectors, MSD pro billet distributor, MSD blaster coil,
I bought the 302 gt-40 crate engine and it claims 345hp, dyno'd with 65mm tb and headers. My setup is almost indentical to u. Im expecting about 370hp...maybe more. So with a 351, u could expect 400- 415hp. I also depends on ur cam and heads. Some 351's have much more power than others.
__________________
GT40x alum. head crate engine w/ 3.55's and other things...
It's alot easier if you could give us some 1/4 times first...that way, we we could calculate your approx. HP and what your car could or should run based on your trap speed and 60' times.
__________________
1982 GT 351w(.060),10.7:1 flat top pistons, ported & polished heads, 1.94/1.60 valves,stealth intake, 750 holley dp, Comp 274XE cam, C-4 tranny with 3700 stall converter, 8.8 rear, 4:10's, subframes,electric fan.
Tons of mods that are too much to list
yeah, but what about tsunamis???? (bad joke I know but I just couldn't resist it!)
__________________
retired and drag racing all I can now that I have the time!
13.533 @ 96.24 mph w/1.780 60', ALL THROTTLE, NO BOTTLE! 13.557 @ 98.24 mph most recentl
