View Poll Results: A poll
Voters: 85. You may not vote on this poll
Predict RWHP for my project for fun
The build should be done in the next 4 weeks or so. I haven't built one since 1979. After a short "break in" I will tune it on the dyno and post the results.
Here's the build; If you need more specific info let me know.
Car -1988 GT
Dif - 373 positrac
trans - TKO
Engine - 347 stroker with girdle
Hawks Racing Forged Crank
SCAT forged H-style rods
Deck milled for correct heigth and compression
Trick Flow Forged pistons 9.1/1 compression
Custom fit of all pistons (.003) and file to fit rings with end gap .025
Main journals align honed after girdle install
All bearings and journals matched for clearance and elimination of taper.
All internals individually balance and then complete assembly balanced.
Comp cam .566/.570 lift, duration @ .050 232/236 lobe sep 114, and properly timed.
Rller tappets, roller rockers (1.6), and roller chain assembly
1/2" head studs
Trick flow heads with 2.02 and 1.60 valves, ported
Typhoon performance plus intake, gasket matched, phenolic spacer
42# Ford Racing injectors with matching MAF meter
Mallory Hifyre ignition
Paxton NOVI 1000 SC with 6# boost
BBK shorty headers
MAC off road H pipe
Prochamber catbacks
[IMG]local://upfiles/10436/F95842DB50694EC892AC98B65AEBF7DA.jpg[/IMG]
Car -1988 GT
Dif - 373 positrac
trans - TKO
1/2" head studs
BBK shorty headers
MAC off road H pipe
Prochamber catbacks
RE: Predict RWHP for my project for fun
ORIGINAL: Dbeck002
why did you post a poll when you coulda just asked what we think power will be. lol..
id say around 550.
id say around 550.
