347 stroker which head will work?
Please help:
I have a 347 Eagle stroker kit part number 16022, pro built short block, with a Ford F cam installed, need some help in figuring out which head intake combo to use. I have been told with the piston setup i cannot run a Trick Flow head, Eagle has a diferent part numb. for that setup.So im thinking maybe AFR 165, will they work? and for a intake maybe Trick Flow Track heat ? any info would be helpfull
The car is going to be used for driving on the street and with no blower or bottle.
RE: 347 stroker which head will work?
I'M USING AFR. 185 HEADS ON MY 347 STROKER. AND IT'S A SCREAMER TOO. WITH 125 SHOT, 300 STAHL, 410 GEARS...
[IMG]local://upfiles/76476/255D0C2EC3D94C1B864F30FC14FABC52.jpg[/IMG]
im gonna be using canfield 195's and a holley systemax intake.
as far as heads for you go with atleast the afr185's if not some afr 205's or canfield 195's.
for intake the trackheat wouldnt be bad but i think the edelbrock rpmII or holley systemax are better.
and you might wanna consider getting a custom cam and ditching that fcam.
YoungStangsMan
09-05-2015 07:01 PM
