question about conventional/synthetic oils
i dont drive my mustang much, maybe once every other week, and i drive it hard whenever i get a chance, i dont know if this is a myth or not but is it better to use conventional if you dont drive much because it sticks to metal or leaves a layer of oil on it or something and synthetics dont? i dont want everything being grinded up the first minute i start the car, then start driving it hard.
thanks.
thanks.
RE: question about conventional/synthetic oils
What sucks is once you use syntheticyou can't go back to conventional, not to mention synthetic is alot more expensive. (but you probably already know that)
ORIGINAL: redstang14
switching from synthetic to conventional isnt the best thing for your motor i mean its not going to explode if you do it once but if you do it a lot it does wear differently and your motors life expectancy will shorten as for conventional being better than syntheitc for an ocassiaonal driver... i really dont think that conventional leaves a layer where synthetic deosnt it will be the same viscosity and weight so it should be the same
