Fuel filter wont come off!! HELP!
So i tried to change my fuel filter today and managed to get the hose off one one end closer to the engine off with my fuel in line release tool , but the one side facing the back doesnt budge! I tried jammin it in there and pulling but nothing. Any one else have this problem?? ANy suggestions
RE: Fuel filter wont come off!! HELP!
The way these ends work is there is a bump in the
metal gas line. There is a plastic ring with two tabs
that fit through two side slots in the fitting. Available
in kits from Advance Auto.
When you insert the line into the connector the bump
pushes past the plastic clip and once it goes past
it the clip snuggs in behind it holding it in.
You have to push the clip so that it expands out more
through the slots while pulling the line out so the
bump easilly pushes past the plastic.
mrappe
09-26-2015 10:16 AM
