Fuel pump
RE: Fuel pump
I changed mine with a NAPA replacement and it worked
fine. However ebay has some sellers that offer OEM
and higher flow pumps a bit cheaper. You will probably
get feedback of their names.
Make sure the tank is near empty. Use a lift
if you can get on one. Any rusting on
the top of the tank when it is down You should
buy a new one $100. May need to replace
the $30 filler grommet if it is loose around
tube.
Crefully remove the hp gas lines with the proper
tool so you can reuse them.
Make sure it is the pump not the underseat relay.
tube.
mrappe
09-26-2015 10:16 AM
