Sponsored by:
Sponsored by: DashLynx
HEADLIGHTS
Old 10-25-2007, 10:54 AM
tim62465
tim62465's Avatar
Default HEADLIGHTS
Is there a website or link that would show the procedures for removal and installing the headlamp assembly for a 03 GT?
Thanks
Tim
tim62465 is offline
Old 10-25-2007, 12:36 PM
MU71L4710N
MU71L4710N's Avatar
Default RE: HEADLIGHTS
are you talking about the headlight mounting bar (the bar that goes across the whole front of the car) or just the headlights themselves?
MU71L4710N is offline
Old 10-25-2007, 03:43 PM
tim62465
tim62465's Avatar
The lens covers are all pitted out and I want to replace the whole assembly…seen some good deals on Ebay but looking at getting them out doesn’t look easy!
tim62465 is offline
Old 10-25-2007, 03:52 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: tim62465
The headlight assemblies themselves are cake walk.
Pop your hood. Look along the back/top side of the headlight. you'll see two little black tabs on top of each headlight. Pull these tabs straight up(they are actually long slender bars). That's all that holds the headlight in. Once you have the bars off,the headlight straight forward (away from the car). Viola! done.
It's the part labeled #2 in the diagram above.
Derf00 is offline
Old 10-25-2007, 11:27 PM
MU71L4710N
MU71L4710N's Avatar
yeah lol its simple, pull the 2 metal pegs on each headlight (you should be able to see em sitting right on top) and the headlight will come free. then theres a plug for the headlight bulb and turn signal with tabs on the sides, squeeze those and pull the plug out of the headlight. then unscrew your bulb if you buy OEM's and need the light housings. it takes 1 min or less to remove each headlight.
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
Drastang
09-29-2015 03:31 PM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: HEADLIGHTS
