Sponsored by:
Sponsored by: DashLynx
Need a heater for the garage
Old 10-28-2007, 03:17 PM
06 MUSCL
06 MUSCL's Avatar
Default Need a heater for the garage
I want to put a heater in the garage this winter. Don't need it to keep the temp. 70 degrees, just above freezing. Something that is economical would be good.
06 MUSCL is offline
Old 10-28-2007, 03:20 PM
Colorado_Mustang
Colorado_Mustang's Avatar
Default RE: Need a heater for the garage
Get a propane space heater. You can use the bottle from a propane grill and they work pretty well.
Colorado_Mustang is offline
Old 10-28-2007, 03:45 PM
MU71L4710N
MU71L4710N's Avatar
thats not really economical though, hell be refilling propane probably twice a week and i think a tank is somewhere around 40 bucks isnt it? thats gonna get expensive QUICK.
id check around for those electric space heaters and check out how much power they draw then figure out what it would do to your electric bill.
MU71L4710N is offline
Old 10-28-2007, 04:08 PM
OnyxCobra
OnyxCobra's Avatar
I used a propane heater a lot last winter, it actually ran for many many hours on one tank. Refills are around $20. No method is gonna be really cost efficient unless your garage is insulated like the rest of your house.
I believe electric heaters usually use a ton of energy.
OnyxCobra is offline
Old 10-28-2007, 04:13 PM
corvetteguy
corvetteguy's Avatar
A 20 pound tank costs about $15 to refill at an
agway or so. A 5 gallon container of kerosene
cost $15 or so for a torpedo heater.
Both emit FIRE and I would not recommend it
running without you there. They will , However,
heat the garage warm enough for you to work.
It might be cheper to just get a $25 ELECTRIC
MAGNETIC HEATER TO KEEP THE oil
warm in the car. Probably 150 watts each.
You could go for an air oil burner from a camper
that will run on low speed with an oil tank.
corvetteguy is offline
Old 10-28-2007, 04:33 PM
GreyStang
GreyStang's Avatar
Is the garage insulated? If not then it's gonna cost a fortune just to keep it above freezing. How cold does it get where you live, in winter?
GreyStang is offline
Old 10-29-2007, 09:07 PM
351W THUNDER
351W THUNDER's Avatar
a candle sets of a good flame
351W THUNDER is offline
Old 10-29-2007, 09:15 PM
butch86
butch86's Avatar
well if your garage isnt connected to your house and you dont mind the smell look for a used oil buring heater. alot of garages have them and when they go out of business they are always selling them. then just save all ur used motor oil and tell your buddies to bring over their used oil its cheap heat. and recycyling as well
butch86 is offline
Old 11-01-2007, 01:24 AM
johnnyhou
johnnyhou's Avatar
If you have natural gas in your garage like I do, at my hot water heater, then a natural gas space heater is definitely the way to go.
johnnyhou is offline
mrtrodonet
09-19-2020 03:12 PM
chrisdbassplayer
10-13-2015 06:53 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Need a heater for the garage
