high oil pressure on 5.0 mustang
I have a 1995 gt mustang 5.0 and the oil pressure is pretty high its almost at the H, most of the time it stays at the L at the end of the normal, and I'm wondering why its so high. Does anyone have any ideas on the possible problem? Any help would be great, Thanks for your time.
RE: high oil pressure on 5.0 mustang
Hmm you are talking about the stock guage right? The sender for that is pretty much just an on/off deal so normallyitshows about 60% no matter what the pressure is as long as its over... 6psi?
bearing clearances would give you high or low oil pressure. Do yourself a favor and borrow or buy a mechanical oil pressure guage and check it, if your just going to test it using a mechanical by all means use the supplied nylon tubing but if your going to keep it permantely get some copper tubing or braided steel lines for it. ITS CHEAP INSURANCE, if the nylon decides to crack .
Soldier GT
08-12-2015 03:46 PM
