Sponsored by:
Sponsored by: DashLynx
System running too lean... why???
Old 11-29-2007, 05:05 PM
olvanish
olvanish's Avatar
Default System running too lean... why???
I know I'm at the wrong forum, but being an owner of a Stang this is the only one I got an account on. My dad's 2003 F-150 4.2 V6 had a service engine soon light come on a few days ago. Thetruck is running completely normal though. I connected it to an OBDII reader and it gave me 2 codes which are p0171 and p0174. The explaination was "system running too lean" and that's for both, bank 1 and bank 2. I first thought it was a bad oxygen sensor, but then why would it be on both banks at the same time? I checked all the vacuum hoses and everything is seems connected right with no leaks or cracks anywhere (the truck has 54k miles on it). I know it can also be caused by a loss of fuel pressure and a faulty MAF sensor which I have not yet tested. I took off the MAF sensor to make sure there's nothing stuck inside and I didn't see a thing. Where should I start or what else could it be? How do I test a MAF sensor? What do I hook up a fuel pressure gauge to? How do I test the O2 sensors without making holes in the wiring to check the voltage? This is driving me nuts, any help is highly appreciated.
olvanish is offline
Old 11-29-2007, 06:38 PM
Cryptostorm
Cryptostorm's Avatar
Default RE: System running too lean... why???
fuel pump or filterfilter
Cryptostorm is offline
Old 11-30-2007, 10:21 AM
ewgoetz
ewgoetz's Avatar
Check your PVC hose. I have a ranger edge 4.0Lthat had the same issue that you are describing. I the issue was a cracked PVC hose. It can also be a disconnected vacum line.
ewgoetz is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
MusicCity615
09-12-2015 07:05 AM
algregory
09-11-2015 11:44 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: System running too lean... why???
