How was my car lowered?
RE: How was my car lowered?
ORIGINAL: Colorado_Mustang
False. Cutting the spring only affects the travel. If you do it improperly and heat the entire spring, then you can affect the spring rate.
Springs designed to be shorter have their spring rates engineered to help the ride. The rough ride you feel with cut springs has to do with the finish of the cut and the limited suspension travel combined with the spring rate. You should always adjust the suspension bump stop when you lower the car to allow the suspension more room to move. This should be adjusted without springs to make sure the arms aren't binding at the limits.
ORIGINAL: Jfsram
First thing you should do is crawl under there and look at the springs. The upper end of the coil will be the first hint if they have been cut or not. If the rest of the spring is mint and the end is bare metal, good chance it's been cut.
Check the spring colour or anything written on them like a part number or a brand, like Eibach.
Cut springs ride like crap because you increase the spring rate as your cut the spring.
ORIGINAL: Jfsram
Have you cut a spring and measured the spring rate and found them to the the same lbs PER inch?
http://www.therangerstation.com/tech...springrate.htm
Change the NOAC to a smaller number. Report back with your findings.
Spring rate is the amount of force needed to move a spring a certain distance. How much force is needed to collapse a spring is based on the rate, but does not change the rate. A constant rate spring that is compressed 50% still needs that x amount of force to move it another certain distance. The total force is different, which is what that website is referring to.
When you get a physics degree, lemme know.
The website if referring to coil spring rate. Lbs per inch.
Bottom line is you reduce the number of active coils. You increase the spring rate.
I don't need a physics degree to tell me that. It's a simple formula.
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
