Sponsored by:
Sponsored by: DashLynx
Forced Induction
Old 12-30-2007, 08:37 PM
tylerl90
tylerl90's Avatar
Default Forced Induction
Does forced induction of any kind, increase gas mileage in any way?
tylerl90 is offline
Old 12-30-2007, 08:44 PM
67mustang302
67mustang302's Avatar
Default RE: Forced Induction
Theoretically, yes.You could build a turbo setup that's designed to provide some boost at low rpm/part throttleto increase cylinder pressure at cruise rpm and throttle position, increasing combustion efficiency. In theory it should increase mileage due to better efficiency. Engines have poor efficiency at low rpm and minimal throttle position, so the boost pressure should allow for more complete and rapid combustion.
67mustang302 is offline
Old 12-30-2007, 11:27 PM
MU71L4710N
MU71L4710N's Avatar
other than some miracle of a design that would cost thousands of dollars to set up the answer is no. you could get nitrous and it wouldnt do anything to your gas mileage until you use it, but the rest are going to burn more gas than your car does right now.
turbo or a blower wont kill gas mileage if you granny it and stay out of boost
its simple numbers
more air = more fuel bieng injected into the cylinders = more power.
MU71L4710N is offline
Old 12-31-2007, 08:11 AM
Blackhawk
Blackhawk's Avatar
Yes, as long as you don't drive over 3000rpm in any gear.
Blackhawk is offline
Old 12-31-2007, 08:57 AM
MU71L4710N
MU71L4710N's Avatar
isnt it like 2000 rpm for a roots style? thought they made boost at lower rpm
Old 12-31-2007, 02:34 PM
tylerl90
tylerl90's Avatar
Thanks.
Note: I was asking this to prove a point. My friend seems to think he's hot s*it and knows everything about cars and made the ignorant statement that "forced induction improves fuel economy by like 5mpg." I laughed at him. Period.
tylerl90 is offline
Old 12-31-2007, 03:23 PM
67mustang302
Yeah, roots/screw superchargers depending on the setup, can start boosting around 2,000rpm. But, it's driven by a belt, so cruising at part throttle you're not really making any usable boost, but still taking power to turn the blower. A turbo can be sized such that it starts boosting at the same rpm, or even lower.
And I doubt you'd get a f/i engine to gain 5mpg unless you purpose built it to specifically do just that.
Old 12-31-2007, 08:46 PM
RJW
RJW's Avatar
ORIGINAL: tylerl90
Thanks.
Note: I was asking this to prove a point. My friend seems to think he's hot s*it and knows eveurborything about cars and made the ignorant statement that "forced induction improves fuel economy by like 5mpg." I laughed at him. Period.
Lets think about it this way. Long bed, quad cab, heavy duty, 4x4 '06 Ram 2500 with a 6.0L CTD. The Cummins itself weighs over 1kLb. The entire package weighs 6500+. Do you think the same 6L would get the same 22 miles per gallon without the turbo?
I can tell you, mathematics and science show that forced indcution can improve fuel economy. More air may mean more fuel, but an astronomical VE and a properly used set-up will yield great results. It just so happens that most FI systems you have seen or paid much attention to were built with pure power in mind. That 6500lb CTD gets single digits when the boost guage is pegged and the soote is pouring out.
RJW is offline
Old 12-31-2007, 08:51 PM
RJW
RJW's Avatar
By the way, I'm not just speaking out of my ****. I don't have any online resources saved on this particular computer, but the book "Maximum Boost" by Corky Bell is a good read if you're interested in knowing a little more about forced induction, specifically in relation to turbochargers.
RJW is offline
Old 12-31-2007, 09:38 PM
jEEd
I ♥ Acer
jEEd's Avatar
theoritically yes, but if you stomp on it , it wont.
jEEd is offline
Quick Reply: Forced Induction
