a couple of problems
I have a 97 V6. I just got the car today and on the drive home I noticed the temp guage wasn't working and the windshield leaks air. Is there an easy fix to both of these problems? Windshield will more then likely have to go to a shop for that repair. Temp guage easy to fix myself or will I be better off taking it to a shop for that also? Any help or ideas would be great. Thanks.
RE: a couple of problems
ORIGINAL: Phantoms
new windshield will fix that "air leaks" and a new temp sensor will fix that temp guage from not working. make sure you buy the right color (green).
Yeah I was thinking I could have the windshield pulled and the weather stripping replaced. A temp sensor is all I will need to correct that problem....sounds easy enough. Thanks for the info jEEd!!
ORIGINAL: Phantoms
ORIGINAL: jEEd
yeah no problem! usually if that guage doesn't work, its the sensor not working correctly, gl w/ the windshield.
ORIGINAL: Phantoms
Check with your insurance company, a lot of companies will replace the winshield if you happen to get a large crack or spiderweb that is too large, and all you have to do is pay the deductable. It depends on your coverage.
ok I just replaced the coolant temp sensor. When I am drinving the needle will sit on the normal line or under. When I am sitting still at idle it will move up to the middle of normal.....then drop back down when I am moving. Too warm out today to tell if heat is any better then it was. Could the Temp Switch be an issue also?
zanemoseley
09-06-2015 12:58 PM
