location of flasher relay - MustangForums.com
Sponsored by:
Sponsored by:
Old 02-03-2008, 07:57 PM   #1
02mustangLV
Default location of flasher relay
Does anybody know where the flasher relay is located on my 02 V6 Mustang coupe? When I put on left or right turn signals sometimes the turn signal sticks and stays on. It isnt consistantly sticking and is always taking different amounts of time when it sticks.
02mustangLV is offline   Reply With Quote
Old 02-03-2008, 08:30 PM   #2
ewgoetz
Default RE: location of flasher relay
Usualy they are under the dash either in the fuse box or next to it.
ewgoetz is offline   Reply With Quote
Old 02-04-2008, 06:43 AM   #3
GreyStang
You can turn on your turn signal & listen under your dash for the clicking, that's the relay, and yup it's usually part of the fuse block
If a flasher relay stays "ON" that's often because on of the outside bulbs are blown, or maybe just corroded if you say it's intermittent. Next time the signal stops blinking turn on your 4-way flasher & walk aroiund the car, make sure all the lights that should be blinking are blinking
GreyStang is offline   Reply With Quote
Old 02-04-2008, 11:05 PM   #4
02mustangLV
Thank's i found its on the right side of the stering colum.....that was the problem the relay.... problem FIX !!!
Old 05-29-2014, 01:32 PM   #5
Miltonmills4
Miltonmills4's Avatar
If your four way flashers work but the turn signals will not work does that mean bad switch
Miltonmills4 is offline   Reply With Quote
2007 Won't stay running -- Possible electric problem Seanam V6 S197 General Discussion 5 10-04-2015 10:15 AM
Secondary air pump relay? 1996cobraconvertible SVT Forums 3 09-30-2015 02:01 PM
Circuit breaker for 92 Vert jc409 Convertible Tech 0 09-26-2015 08:28 AM
Top stopped working yesterday jc409 Convertible Tech 1 09-24-2015 03:38 PM
Fuel pump relay clicking at times while running? schecterplayer 5.0L (1979-1995) Mustang 3 09-23-2015 08:38 AM
02, 1999, 2002, 94, 98, cobra, flasher, ford, gt, located, location, mustang, relay, rely, signal, single, turn
