bulding new engine please help
RE: bulding new engine please help
k i found the answer to my own question, i think im gonna run an EFI system if i get the 408, now what about the motor itself, who sells a good stroker kit? also most kits come with pistons, is it best to use their pistons and what ever else it may comewith?
coast high performance is a good company from what i have heard. their site is www.coasthigh.com . the motor mounts are the same. you have to use 408- specific pistons. the kit comes with forged pistons in various compression ratios, so there is no reason to use other ones.
depends on how much power ur lookin to make. i would suggest gettin it because its a heck of a lot cheaper than a cracked block, but wont be necessary (dependin on power output) because the 351W can handle a bit more power than the 302.
im suspect im going to be needing a new suspension to accomidate the new weight, since i have the heaviest of all mustangs already, what is a good suspension that can hold this weight
go with a 302 stroked out to a 331 or 347 the 351 has a taller deck height so with efi u will need a new cowl induction hood and there is a pretty big weight differance between a 302 and 351, a 331 or 347 will have just as much power if not more then a 351 and most of the acessory brackets will have to be changed if u go with a 351 on a 331 or 347 u can just use ur old ones. well good luck on what ever u do [:@]
