bulding new engine please help
#21
RE: bulding new engine please help
thanks for the info the project got postponed tho, i had to replace a few things on the car and now im out of money for a while, but i may just buy a project stang, like a 93 or something and then when its ready build my 408 not sure yet but that might happen too, keep my 95 as daily driver
#22
ORIGINAL: 1fststang
go with a 302 stroked out to a 331 or 347 the 351 has a taller deck height so with efi u will need a new cowl induction hood and there is a pretty big weight differance between a 302 and 351, a 331 or 347 will have just as much power if not more then a 351 and most of the acessory brackets will have to be changed if u go with a 351 on a 331 or 347 u can just use ur old ones. well good luck on what ever u do [:@]
#23
cool i also found an 88 with a 4 cl. in it with T-tops, a little body damage but repairable, only $700 and it still runs i might use that for my project car but im waiting to hear back form the owner so i can go look at the car
#26
i finally got my project car its an 89 LX, paint has already been sanded off and some bondo applied, needs a little bit of bodywork on the rear half, its missing door pannels and a few latches for trunk hood and one of the doors, this is gonna be my 408 stroker car ill get pictures of it up soon
#28
here you go moocow-v ,,heres my set up /408 ..4340 interals...12.5to1 comp..victor jr heads 2.05/1.60 heads flow only 291 int 198 exh,,just bowl blended,,solid roller cam specs are 264/272 at .050 lift ..lift is .701/.688 ,1.72 rockers .stud girrlde , super victor intake ,,1000 cfm demon carb..,canton oil pan..msd dist ,dig 6 box, and cheater nos system adjust to 250 hp..200now..that the motor ..tko trans,center force clucth,,pro 5.0 shifter,,alum d/shaft..8.8 with 31 spline mosers..got c-clips..stock trak lock..3.73s .got anti roll bar ,,8 point cage 10 on the way ..flaming river manaul rack..iam sure i leaft something out.
#30
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
