MECHANICAL SECONDARIES
Old 04-07-2003, 02:46 PM
David429
David429's Avatar
Default MECHANICAL SECONDARIES
I have an 800 cfm Holley with mechanical secondaries. Is this a good carb to run on the street on my 429 Ford?
Is there an advantage or disadvantage of the mechanical as opposed to the vacuum secondaries?
David
David429 is offline
Old 04-07-2003, 05:36 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
Go fuel injected.
jeep45238 is offline
Old 01-22-2004, 12:09 PM
WNDSOR
WNDSOR's Avatar
VACUUM CARBS ARE MORE STREET FRIENDLY AND LITTLE MORE FUEL EFFICIENT, THOUGH WITH A 429 THAT DOESN'T MUCH MATTER! THE MECHANICAL WILL OPEN THE FOUR BARRELS UP MUCH QUICKER,NOT HAVING TO RELY ON VACUUM. USUALLY MECHANICALS ARE STRICTLY USED AS PERFORMANCE CARBS BUT I ACTUALLY RUN A 600 MECHANICAL DOUBLE PUMPER ON THE STREET FINE, I DONT DRIVE IT EVERY DAY, BUT IT DOES REALLY WELL WHEN TUNED RIGHT.
WNDSOR is offline
Old 01-22-2004, 01:30 PM
vfast
I ♥ Acer
vfast's Avatar
800dp..naw..a 700dp would would great or even a 650 dp with a stub stack and some tweaking....with my 427 nova I run a 700dp on the street and if I race I throw on a 850dp..and if a go to the track I tune it up and use a 1050 dominator
vfast is offline
Old 01-22-2004, 04:33 PM
DW-03GT
DW-03GT's Avatar
Depends on cam size, compression, rpm's, port and polish work, If your close to stock it's going to be too much carb, you need to run really small jets in it to try compensate.</P>
If your runnig 15:1, roller cam and spining 7500 RMP it's too small, depends on the total package, that a big mistake people alway make, you need to look at everything</P>
DW-03GT is offline
Old 01-22-2004, 06:48 PM
vfast
I ♥ Acer
vfast's Avatar
that's why a 750 vacuum secd. would be a good carb
vfast is offline
Old 01-22-2004, 06:52 PM
vfast
I ♥ Acer
vfast's Avatar
my truck has a 408 chevy big block with oval port heads with big *** 2:19-1;88 valves a small 575/563 108 c/l cam torker intake,10-1 pistons runs 11.99 and pulls the trailer as I use a tricked out 650 dp..it revs quick and it lights up the 295-50-15 's hooked up pulling a trailer and car*L*
vfast is offline
Old 01-22-2004, 07:06 PM
WNDSOR
WNDSOR's Avatar
i thought this was a ford forum vfast!
WNDSOR is offline
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
07-05-2020 03:05 AM
69Volunteer
09-30-2015 10:39 AM
marc954
09-29-2015 03:05 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: MECHANICAL SECONDARIES
