Sponsored by:
Sponsored by: DashLynx
Trans Fluid..
Old 05-31-2005, 03:23 AM
Black Snake
Black Snake's Avatar
Default Trans Fluid..
Hey everyone I just got a Newly rebuilt T-5 tranny from my mechanic and I forgot to ask him what fluid to use and I dont have his number anymore.
My question is what kind of oil do I use in a stock T-5 Standard Tranny? My dad told me to use gear oil and somone else told me to use Automatic Transmission oil I dont know who to believe little help please, Im putting the tranny in tomarrow.
Black Snake is offline
Old 05-31-2005, 03:43 AM
primetime5.0
primetime5.0's Avatar
Default RE: Trans Fluid..
This 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity) is designed for use in manual transmissions and transaxles. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting. Popular in many BMW transmissions and in most Honda and Acura transaxle applications.
primetime5.0 is offline
Old 05-31-2005, 03:47 AM
philthy89fifty
philthy89fifty's Avatar
t-5's use regular old atf.
philthy89fifty is offline
Old 05-31-2005, 05:20 AM
Black Snake
Ok thank you will be most usefull for tomarrows install, Im in for a long day. Got the old Tranny out 2 days ago but now I got to put the new one in, im doing it myself so I hope I dont screw anything up.
Old 05-31-2005, 05:26 AM
Black Snake
Oh yeah btw I also got a new Hursts shifter and I was wondering is it hard to put in and what are the steps in doing this?
Old 05-31-2005, 06:14 AM
philthy89fifty
nah it's all straight forward. if your using a new clutch make sure you keep everything clean that can mess up a new clutch also break it in before you start doin hard launches. i know after all that hard work you want to whip it and hear the second gear chirp the tires but you should kick back for about 50 miles so the clutch has time to break in.
again man get a second opinion on gear oil i've heard it's not good for your tranny and all the manuals say use atf.
Old 05-31-2005, 07:10 AM
Black Snake
Ok thanks I will do that. But no im not using a new clutch I didnt even take the bellhousing off just the tranny. So when I put in the new Shifter its just basic bolt on? Dont have to worry about lining anything up?
Old 05-31-2005, 07:42 AM
Demon_Mustang
Demon_Mustang's Avatar
Hey, I'm not sure who's advice you're taking, but make sure you use automatic transmission fluid. Do not use regular gear lube like with most other manual transmissions. For the T-5, you actually do have to use ATF. This is straight from Ford, not just my opinion.
Demon_Mustang is offline
Old 05-31-2005, 09:51 AM
Quik
Quik's Avatar
atf, others will mess you up
Quik is offline
Old 05-31-2005, 10:30 AM
86HOGT
86HOGT's Avatar
ATF!
86HOGT is offline
Quick Reply: Trans Fluid..
