99 mustang gt power window trouble
Old 12-02-2008, 02:55 PM
Mikes99Mustang
Mikes99Mustang's Avatar
Default 99 mustang gt power window trouble
Hey, I was wondering if anyone can help me, my car is up for storage and i need to fix a few things over the winter, the first priority is the power window, the driver's side does not work. i replaced the motor, the switch, and rotated all the relays under the dash clockwise to see if that made a difference, it still doesnt work. If you hit the power window switch in the down position, the window will drop down about a 1/4" each time you hit it, the switch does nothing to put the window back up though once you get it all the way down. I can hook a battery charger up to the connector on the motor, and it will put the window up or down, depending on which way you place the polarity. So that tells me that the switch and motor are good, If anyone can help, let me know
Mikes99Mustang is offline
Old 12-02-2008, 05:40 PM
Bullitt2theHead
Bullitt2theHead's Avatar
Im assuming if youre hooking a battery charger to the motor, you got the door panel off, so watch the window regulator as you move it up and down. if its got alotta flex in it, it could bind up the window in the run, and trip the breaker.
Thats about the only thing you havent replaced, so check it out.
Bullitt2theHead is offline
Old 12-03-2008, 11:05 PM
Mikes99Mustang
do u know where this breaker is located? is it up under the dash do u know?
thanks
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: 99 mustang gt power window trouble
