OnDemand 5 - Repair help for you.
Old 02-04-2009, 10:38 PM
  #21
Juno
Juno's Avatar
Originally Posted by 95 madness
ok I have a question I have a 95 gt 5.0 HO and I am looking to put a 94 to 97 5.8w roller motor in it can I use everything off my 5.0( intake set up, all front accessories and use the same oil pan and mounts just have to replace oil pump off the 5.8 to the 5.0 set up)
This are repair tutorials not an engine swapping (tuning) tutorials.
Juno is offline
Old 02-07-2009, 01:09 PM
  #22
mustang35
mustang35's Avatar
Hey I just joined the forum and saw your posting Juno. I've got a '99 Mustang Convertible. I'm wondering if you have repair info on the rear defogger. Mine quit working. Checked the fuses and they're fine and the button lights up. But the window will not defog. Any help would be great.
mustang35 is offline
Old 02-07-2009, 02:42 PM
  #23
Juno
Juno's Avatar
But the front DEFOGGER is working?
Both are on the same SWITCH?
Juno is offline
Old 02-07-2009, 03:42 PM
  #24
mustang35
mustang35's Avatar
Front defogger works. I'm at a loss. The rear window will not defog at all. Not sure if there is a problem in the wiring going back to the window though.
Old 02-07-2009, 03:51 PM
  #25
Juno
Juno's Avatar
its nothing about this...
I can give you an wiring diagram for defoggers but thats all... Also something about switch but i dont think that switch is broken...
Just let me know what you want
Juno is offline
Old 02-07-2009, 04:45 PM
  #26
mustang35
mustang35's Avatar
I'll take the wiring diagram that you have. Thanks for the help. I'll let you know what I find out.
Old 02-10-2009, 09:40 PM
  #27
1Low5.0
1Low5.0's Avatar
Default Sun Visor replacement
1989 Mustang LX Convertible
Replacing both existing OEM Sun Visors with 2 new replacements. Any information would be helpful.
Thanks much,
1Low5.0 (oh)
1Low5.0 is offline
Old 02-16-2009, 04:33 PM
  #28
yeewiz
yeewiz's Avatar
Default A/C Vacuum Line Diagram?
Hey Juno, you were such a fantastic help the last time on programming my remotes, I'm BAAAAACKKKK. Do you have a diagram for a 98 stang V6 3.8 A/C vacuum lines, or the vacuum distribution block? Anything on vaccuum lines in the engine compartment if the above 2 topics come up short. Dude, once again, you are the MAN! Thanks!
yeewiz is offline
Old 02-16-2009, 09:26 PM
  #29
jwalker3472
jwalker3472's Avatar
Default I need help
I have replaced the calipers on my 02 coupe. The problem is I cannot get the springs to the e-brake on to the caliper any suggestions?
jwalker3472 is offline
Old 02-17-2009, 05:16 AM
  #30
JRS98SVTCOBRA
JRS98SVTCOBRA's Avatar
HI JUNO DO YOU HAVE INFO OFR REPLACING ROD BEARINGS ON MY 98 COBRA VERT TRYING TO FIGURE OUT HOW TO GET THE OIL PAN OUT WITH OUT PULLING THE ENGINE OUT
JRS98SVTCOBRA is offline
Quick Reply: OnDemand 5 - Repair help for you.
