I have a 1988 ford mustang gt, no moon roof.
can you pin point connection C406. I gave the schematic but i don't know where the connection is. The reason i ask is because my dome light doesn't work.
how to hook up vacuum lines to a 73 ram air Mach 1
I have a 73 Mach1 with ram air and can not find out how to hook up the vacuum lines to the carb etc. It is a 351 Cleveland 2v. Any help would be greatly appreciated.
I also have problem with remotes. Any info on what module controls the remotes? tried but car will not enter program mode. any help would be appreciated. 2001 cobra
Need help installing the cowl vent panel on 2000. Broke the old one and need to find one as well. Does the roof molding have to come off? It seems to over hang the panel a little.
hey man, great stuff you got there... i will appreciate if you can help me on my problem...im about to swap a 2007 4.6 engine on my 99 mustang, so a diagram on all the components of the engine and tranny would help alot.
The diagram I need is for a 2007 Ford mustang GT.
Thanks for the help
Im sure everybody will find your
database helpful,
Have 68 Stang convertible. Want to know how to remove dash or dash pad if dash can't be removed. Also need to know how to test heater blower motor (have already removed assembly; 3-speed switch, two wires coming from motor in engine compartment (yellow and brown). If you can help I sure would appreciate it. Thanks!
