rear quarter panel window will not go up!
Old 06-08-2005, 05:02 PM
socal harley
socal harley's Avatar
Default rear quarter panel window will not go up!
I just tried to put up my rear windw in my 89 vert and it seems like it is off track or something. I hear the motor running fine. I tried to pull up on window while pushing switch up with no luck. Do I need to open up back panel to put it on tarck? If so what is the best way to do that?
Thanks alot!!
socal harley is offline
Old 06-08-2005, 11:15 PM
fordguy17
fordguy17's Avatar
Default RE: rear quarter panel window will not go up!
best thing to do is pull the panel.
i don't have a vert, but on my hatchback there's a couple screws and you should be able to pull the panel off. it will be held on by little clip things from the inside.
its not that hard. just get out there and fool around with it.
fordguy17 is offline
11-10-2015 11:39 AM
DreadPirateRoberts
09-26-2015 02:11 PM
2k232
09-16-2015 10:28 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-01-2015 08:16 PM
Quick Reply: rear quarter panel window will not go up!
