Right turn signal is solid, no blinking...
Old 06-10-2005, 01:00 PM
KandyMan
KandyMan's Avatar
Default RE: Right turn signal is solid, no blinking...
SORRY IM ALL OUT MY SPORT TRAC DOESNT USE THE HYDRAULIC FLUID ITS PNEUMATIC
KandyMan is offline
Old 06-10-2005, 01:01 PM
73Cleveland
73Cleveland's Avatar
LOL - Good one!!!
73Cleveland is offline
Old 06-10-2005, 02:03 PM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
it would likely be a burned out bulb somewhere. run through all the checks with someone outside the car. brakes, signals, headlights, everything......something will be burned out somewhere. If not, then start looking at the connections.
MikeHawke is offline
Old 06-10-2005, 02:19 PM
99saleen351r
99saleen351r's Avatar
ORIGINAL: luckythirteen13
^^^^^^exactly. when a bulb burns out, the blinker stays solid so that you know a light is out
No it doesnt it blinks fast when a bulb is out come on guys you dont know that?
99saleen351r is offline
Old 06-10-2005, 03:47 PM
73Cleveland
I beg to differ but a bulb out is one cause of the light on the other end of the car to come on but not blink. I've been there with that.
On my 73 Mach I had 1 of 2 bulbs out in my right tail light assmebly go out and that caused the right front to stay on and not blink. Replaced the rear bulb & problem solved.
Maybe different years act differently by I speak from experience with mine. I think it has to do with the way the harness is wired during the different model years. Maybe yours blinking fast is getting the current intended for the bad bulb causing the flasher to work faster. On mine it looked like the circuit is open not allowing the flasher to blink.
Old 06-11-2005, 12:38 AM
Casper98GT
I ♥ Acer
Casper98GT's Avatar
I have had it different for everything. My crown vic, the light stayed solid. My taurus the light blinks very quickly. Most likely just a bulb, but could also be the Multi-function switch.
Casper98GT is offline
Old 06-11-2005, 11:41 AM
73Cleveland
Yep, I agree it's most likely a bulb. If it's not though, a test light is invaluable in determining what the problem is whether it's a multi switch, dirty socket, or ground problem. Replacing parts that aren't bad gets expensive.
Old 06-11-2005, 09:38 PM
FoxGT
FoxGT's Avatar
ORIGINAL: 73Cleveland
You could be on to something there. It may be the blinker fluid afterall. Maybe bad muffler bearings caused the muffler to heat up which in turn caused the blinker fluid to heat up and boil the blinker fluid out.
Maybe you have some extra there you could send?
There was actully a part called a muffler bearing on an old chevy truck. It wasn't really a ball bearing type mechanism, it was just a single ball,
FoxGT is offline
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Right turn signal is solid, no blinking...
