Sponsored by:
Sponsored by: DashLynx
car not performing right!!!!
Old 06-13-2005, 05:35 AM
crankinponies
crankinponies's Avatar
Default car not performing right!!!!
i have a 1990 mustang 5.0, 5-speed, i recently cleaned the MAF sensor, throttle body, to fix my idle problems, i have noticed that the car has a slight hesitation when revving at an idle, and tonight i drove the car kindove hard, and i noticed that it isnt really performing like it should. from a dead stop the car doesnt seem to get up and go like it should. PLEASE HELP!!! thnx
crankinponies is offline
Old 06-13-2005, 05:47 AM
92hatchLX
92hatchLX's Avatar
Default RE: car not performing right!!!!
Is it completely stock, if you have any mod.s list them.
92hatchLX is offline
Old 06-13-2005, 06:06 AM
crankinponies
my car is not stock, it has the following mods:
~port and polished heads
~3.90 gears
~k&n air filter
~TKO transmission
~short throw shifter
Old 06-15-2005, 01:02 AM
crankinponies
SOMEONE PLEASE, I NEED INFO ASAP!!!!!!!!
Old 06-15-2005, 06:21 AM
HAUS
HAUS's Avatar
maybe you should try to adjust your TPS(throttle possition sensor) or try cleaning your IAC
HAUS is offline
Old 06-15-2005, 04:00 PM
Deannostang
Deannostang's Avatar
You have to be very careful when you clean your MAF sensors. They are delicate and can damage easily. If you have damaged them at all, your call will run rough. In that case, you will need to buy a whole new MAF. A bad IAC and/or O2 sensors can also cause all kinds of grief with your engine. Best bet so you don't go wasting lots of time and money in the wrong direction is to get your engine scoped. The readout should tell the tale.
Deannostang is offline
Old 06-15-2005, 05:57 PM
99saleen351r
99saleen351r's Avatar
ORIGINAL: crankinponies
~3.90 gears
~k&n air filter
~TKO transmission
You ported and polished a stock steel head?????Why may I ask?What makes you think the car isnt performing up to par?I've never heard of someone cleaning a mass air flow what made you want to do that?!If you break that little wire in there its gonna cost ya a couple hundred for a new one Id be willing to bet thats what it is.
99saleen351r is offline
djbigskrilla
09-20-2022 01:04 AM
MusBBad95
08-17-2015 09:39 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: car not performing right!!!!
