Sponsored by:
Sponsored by: DashLynx
DELETING SMOG PUMP
Old 06-29-2005, 09:27 PM
SmokeRicers
SmokeRicers's Avatar
Default DELETING SMOG PUMP
hey guys just wondering how deleting your smog pump helps your performance? does it mess with emissions any? any feedback would help thanx
SmokeRicers is offline
Old 06-29-2005, 11:38 PM
StangTangGT
StangTangGT's Avatar
Default RE: DELETING SMOG PUMP
not really, when i bypassed my smog pump a while back it felt about the same power gained as when i put my underdrive pullies in. its definitely worth it. it didnt screw with my emmisions/ drivability or anything.
StangTangGT is offline
Old 06-30-2005, 12:57 AM
SmokeRicers
so wats the purpose of a smog pump?
Old 06-30-2005, 01:37 AM
02StanGT
02StanGT's Avatar
ORIGINAL: SmokeRicers
Correct me if I'm am wrong, but I believe it is to mix air with your exhaust. You know the saying "Dilution is the solution to pollution".
02StanGT is offline
Old 06-30-2005, 12:06 PM
GreyStang
GreyStang's Avatar
I thought the smog pump diverts some of the exhaust gases back into your intake charge?
GreyStang is offline
Old 06-30-2005, 01:55 PM
fordguy17
fordguy17's Avatar
ORIGINAL: GreyStang
thats egr.(exhaust gas return)
the smog pump adds air into the exhaust. i think it helps burn more hydrocarbons or something.
i don't have emissions so no smog pump for me, but if you have emissions testing you might wanna check to see if you can remove it.
also if you still have your cats, they will clog or burn up without a smog pump.
fordguy17 is offline
Old 06-30-2005, 07:06 PM
Monch
Monch's Avatar
what he said.
adds air to the mix before the cats. the catalytic reaction takes the oxygen and combines it with unburned fuel on a metal surface to make water and co2 from the unburned hydrocarbons. an excess supply of oxygen makes sure the reaction rate stays as high as possible.
Monch is offline
Bokeo
10-10-2015 08:28 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Teddi
09-29-2015 12:24 PM
Quick Reply: DELETING SMOG PUMP
