Sponsored by:
Sponsored by: DashLynx
x 303 cam
Old 06-30-2005, 12:22 AM
razarr69
razarr69's Avatar
Default x 303 cam
if i were to buy a x 303 cam wud i have to check my piston to valve clearance, ive dun sum looking around and see taht the x 303 is a pretty high lift cam .542/.542 will i have springs with enuf lift with jus stock heads?
razarr69 is offline
Old 06-30-2005, 12:24 AM
StangTangGT
StangTangGT's Avatar
Default RE: x 303 cam
definitely need to check ptv clearance and some upgraded springs are needed any waycause im assuming the operating range is quite a bit higher than stock correct? is there any reason you want to go with this particular camshaft?
StangTangGT is offline
Old 06-30-2005, 01:44 AM
razarr69
razarr69's Avatar
yeah its a pretty high lift cam and i found a good price on one off of ebay but i was thinkin that id need sumwhere like a .500 lift at the most cuz i think thas all tha stock springs can handle, what happens if i get too high of a lift of a cam and the springs cant handle it. what kind of cam shud i be gettin, cud u give me a site where i cud possibly buy it. thanks
razarr69 is offline
Old 06-30-2005, 01:30 PM
5.0mustang5speed
I ♥ Acer
5.0mustang5speed's Avatar
.500 lift..oo how cute
5.0mustang5speed is offline
Old 06-30-2005, 02:53 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
You would be better off with the E303 and some 1.6 rockers. Thats a pretty safe setup and it sounds awsome! My buddy installed that in his and it runs and sounds like no other.
jdaniel is offline
Old 07-01-2005, 02:55 AM
StangTangGT
yea i have the e-303 with 1.72 cobra rockers but i have my pistons notched as well. and i love the idle and sound.
Old 07-01-2005, 02:57 AM
StangTangGT
dood you dont have to just buy a ford alphabetical cam. go to comp cams they have some wicked cams that your ptv will be ok with. besides valve springs are not that expensive/hard to replace.
Old 07-01-2005, 10:52 AM
FoxGT
FoxGT's Avatar
X303 Equipped With stock springs even! [sm=smiley20.gif]
FoxGT is offline
Old 07-01-2005, 12:34 PM
P Zero
P Zero's Avatar
X303 is just fine with stock valve springs as long as they dont got a **** load of miles on em. Definitly check the valve clearance. I run a wolverine cam .496/.510 with 1.72 omegas, I also use heavy duty double dampend springs though. What heads are you runnin that you would use this cam? Most people over cam their motors and actually lose power. So you might wanna check into what would be a better cam for your setup.
P Zero is offline
Old 07-01-2005, 10:48 PM
razarr69
razarr69's Avatar
yeah im jus gunna go fer a mild build up i think id prolly replace tha rockers n springs if i got a new cam, but id jus leave the heads fer now. after lookin more into tha e 303 cam it seems like itd suit my needs better than the x 303. i got a half *** idea how to put a cam in but i think id **** up on sumthing little so ill prolly have to wait a bit till i get more cash to buy one n tha rockers n springs n get a mechanic to put it in. i havent really looked into like any comp cams, crane or lunati ones. what one would you suggest?
razarr69 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: x 303 cam
