Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-27-2009, 04:23 AM   #1
benji1246
Vehicle: 2001 ford mustang gt
Default 8.8 Rear end slop
My rearend in my 01 gt has lots of play in it.
When i remove the driveshaft i can turn the rear almost 2 inches back and forth.
What would cause this?
When i press the gas and let off at low rpms it clanks in the rear also.
benji1246 is offline   Reply With Quote
Old 06-27-2009, 11:03 AM   #2
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
So you saying that the entire rear axle moves 2" fore and aft OR side to side? 2" does seem excessive.
Fore and aft movement could be severely worn control arm bushings. There is also a large pinion snubber that is meant to control axle 'twist' (wrap up).
Side to side movement is control mainly by the panhard bar. It also has bushings that can wear out.
__________________
Greg - Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
Old 06-27-2009, 02:46 PM   #3
benji1246
I meant to say the pinion turns 2 inches back and forth before it turns the wheels.
Old 06-27-2009, 02:55 PM   #4
socalwrench
That is known as backlash- a clearance between the pinion gear and ring gear. I don't know the spec. off hand, but some play is normal.
__________________
Old 06-27-2009, 03:01 PM   #5
benji1246
I checked some other vehicles of mine and they have like only 1/2 inch of play.
Old 06-27-2009, 03:11 PM   #6
socalwrench
Yes, 2" does seem excessive.
__________________
Old 06-27-2009, 03:42 PM   #7
benji1246
could it be the spider gears???
Old 06-27-2009, 04:29 PM   #8
socalwrench
Try this: apply the emergency brake with the vehicle on the ground and in neutral (on level ground). Try to move the driveshaft by hand in either direction again. The emergency brake will prevent the axle shafts and spider gears from moving. If there's still excessive play- then the ring and pinion are your culprits.
__________________
Old 06-27-2009, 06:00 PM   #9
benji1246
Yes it still does the same thing.
Old 06-28-2009, 12:16 AM   #10
socalwrench
Well, I think that we've figured it out then- excessive backlash. This can be adjusted using shims, but depending on the mileage- a differential rebuild or gear set replacement may be needed soon.
__________________
7, 88, axle, differential, end, ford, gear, lot, mustang, play, rear, rearend, rebuild, slop, spider
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
