First off, do you hear the compressor relay clicking? It is located inside the passenger wheel well. If it's clicking, than you can safely assume that the dash controls are working.
If the compressor is not engaging- it could be because of the low pressure switch. If you get a leak- then that switch will prevent the compressor from turning on.
Before you decide to fix this- you will need to buy or borrow a set of gauges (for R-134a).
You need to do is figure out if there's any pressure and/or refrigerant in the system. If there's a leak- you can either use the refrigerant with dye in it OR pressurize it will an enert gas like Nitrogen and watch the gauges. Once you know if there's a leak or not- you can proceed to fix the leak and than evacuate and refill with refrigerant (R-134a on your car).
If you need to replace the compressor- you will need to remove the refrigerant that's in the system into a designated container. As long as your receiver/drier is working properly- you can safely reuse the refrigerant (it doesn't go bad). Plus, this way you don't have to adjust the oil level in the system either.
One last piece of advice- DO NOT OVERFILL the system with refrigerant. Because of the operating pressures of R-134a- it will not get as cold.
__________________
Owner/Operator: GRH Performance
