New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-02-2009, 10:53 AM   #1
DarkJFMan
DarkJFMan's Avatar
Vehicle: 2009 Mustang GT
Default 3.73 Gears
I've been wanting to buy these FRPP 3.73 gears and with my luck they're on sale at AM.
Before I buy them there's two options you can add to it.
1) Add Kit: (recommended)
a) Add master bearing kit
or
b) Add installation kit
2) 8.8 Rebuild Kit w/Carbon Discs
Out of the kits which one would I need. And can someone please explain those?
Thanks in advance.
DarkJFMan is offline   Reply With Quote
Old 07-02-2009, 03:49 PM   #2
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
This really depends on how many miles you have on the axle. Some of the parts can be reused, while others can't. I don't think you need a rebuild kit (w/ clutches for the LSD) if it's new.
__________________
Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
Old 07-02-2009, 04:49 PM   #3
DarkJFMan
DarkJFMan's Avatar
Right now I only got 1600 miles on my car... Pretty brand new so can I just buy the gears? Without the master bearing kit or the installation kit?
Also around what mileage would I need to replace them?
Old 07-02-2009, 08:29 PM   #4
socalwrench
I went ahead and looked at the AM site (my wife doesn't like it..... , BUT I do.... ). Anyway, typically differential bearings will last approx. 100k miles before needing replacement (with normal driving). However, you WILL need the installation kit for $36- mainly because it gives you a new crush sleeve (which isn't reusable), and pinion nut and ring gear bolts (which may not be reusable according to Ford). Other things like the shims, marking compound and loctite just make the install easier.
__________________
Old 07-03-2009, 11:06 AM   #5
DarkJFMan
DarkJFMan's Avatar
I appreciate your help again. Now at least I'm not lost.
373, gears
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
