Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-03-2009, 09:53 PM   #1
VRB
Vehicle: 2004 Ford Mustang GT
Default How do I replace the belt on my 04 GT?
Looking for instruction or wher to download instructions on replacing the belt in my 2004 Mustang GT. Appreciate any direction!
VRB is offline   Reply With Quote
Old 07-03-2009, 10:29 PM   #2
AirBrontosaurus
First and foremost, WRITE DOWN THE BELT LAYOUT. When you take the old one off, you'll need to get it back on and in the same order or else there will be problems.
To take the belt off, take a socket wrench (I can't remember if it's 1/2" or 3/8"), and if there's a socket on the end take it off. Put the square end of the wrench into the notch on the tensioner (it's a pulley on the end of a swinging arm), and then turn the wench until the tensioner relieves itself and the belt just falls off.
Take the wrench off the tensioner.
Re-route the belt around the pulleys, skipping the tensioner. Once it's routed, put your wrench back on the tensioner, rotate it again, slide the belt over the tensioner, and then release the tensioner from the socket wrench.
The whole thing should take less than 15 minutes.
Good luck!
AirBrontosaurus is offline   Reply With Quote
Old 07-04-2009, 09:09 PM   #3
VRB
Thanks...appreciate it much!!
Old 07-05-2009, 12:57 PM   #4
AirBrontosaurus
You are most welcome!
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
