Sponsored by:
Sponsored by: DashLynx
Coolant Pumping in Wrong Direction
Old 07-01-2005, 06:51 PM
beckad
beckad's Avatar
Default Coolant Pumping in Wrong Direction
I have a 96 mustang GT that i just had engine work done to. After spending about 6k on the engine the shop cannot seem to fix a problem that they created. They are telling me that the engine coolant is trying to pump in the wrong direction thus causing the engine to overheat. They went to ford and got another pump and double checked to make sure the fins were spinning the right way. They even removed the thermostat and still not working. The top hose colapses after a few minutes and then the car starts to overheat. Please help as I dont think these guys can figure this out.
beckad is offline
Old 07-01-2005, 06:54 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: Coolant Pumping in Wrong Direction
6K on the engine..as in a new engine? Is it spinning clockwise? Did they route the belt the right way? Are they using the same waterpump that came off the old engine? You mentioned they installed a new one, but if the engine is rotating the wrong way, then you're 'right' water pump would work wrong.
Derf00 is offline
mkspeed26
mkspeed26's Avatar
check serpentine belt routing
mkspeed26 is offline
Old 07-01-2005, 07:00 PM
P Zero
P Zero's Avatar
They have the serpentine belt on wrong.
P Zero is offline
Old 07-01-2005, 07:21 PM
beckad
beckad's Avatar
They told me that they check the belt several times.
beckad is offline
Granatelli Sales
01-20-2020 12:34 AM
pimp2303
09-17-2015 08:45 PM
rksnow1
09-14-2015 08:46 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Coolant Pumping in Wrong Direction
