short shifter procedure??
RE: short shifter procedure??
It doesnt need to be "broken in". Just bolt it up and youre off. Its going to feel a little stiffer than stock but it shouldnt be hard top shift. Make sure you adjust the shift stops properly.
See my thread that I posted a few days ago, this should answer most, if not all of your questions after installation:
https://mustangforums.com/m_589644/tm.htm
In addition to the replies I received, I talked with a B&M tech. rep. on the phone and a little vibration is normal - no actions needed to fix. Like P Zero said, just bolt it and go.
junior04
09-28-2015 10:53 AM
