98 StangGT V8
RE: 98 StangGT V8
At 30,000 mi.Check engine drivebelts,ignition system,air filter,PCV,and exhaust system.Change the fuel filter,automatic transmission fluid and filter,and air filter.At 60,000 mi.Replace spark plugs,manual transmission lubricant,and rear end lubricant.I would do everything on this list regardless of the miles.Expect to buy a new set of plug wires,they DO wear out.New spark plugs also.A new fuel filter would be in order.When changing the auto trans fluid be sure to drain the torque convertor also.
evilroger6969
04-24-2008 08:01 PM
