Sponsored by:
Sponsored by: DashLynx
SO WHO HERE USES ARCO GAS?
Old 07-30-2009, 10:21 PM
geryogery
geryogery's Avatar
Default SO WHO HERE USES ARCO GAS?
I began looking into gas octane and what it all means when I started to come across some very interesting articles about Arco. Even though I have always heard some negative opinions about it I have bought Arco anyway because it's always cheaper. Well... I don't think I'm buying it anymore.
Check out what I found on Arco's own web site. http://www.arco.com/sectiongenericar...tentId=7023062
They admit that they create an oxygenated fuel by adding ethanol and go on to state "With any oxygenated gasoline, there will likely be a slight reduction in performed fuel economy by approximately two to four percent."
Four percent less fuel economy??? So it's like I'm getting 4% less gas than I thought. I decided to do the math:
If gas costs $2.75 a gallon,
And I spend $20,
I will get 7.27 gallons.
Deduct 4% from 7.27 gallons and you are actually getting 6.98 gallons.
So if you are only getting 6.98 gallons for $20 then the real price is $2.86 a gallon and NOT $2.75. All of the sudden Arco seems to cost the same as the other brands.
I also read that ethanol is an alcohol that can cause problems in our engines over time. I know that this is a mustang site and not a gasoline site, but I just thought that some of you might like to know.
geryogery is offline
Old 07-31-2009, 11:54 AM
ryan1994mustang
ryan1994mustang's Avatar
all gas stations are putting ethanol in their fuels now. its supposedly a way to reduce petroleum use. a few states, and many large cities require a 10% ethanol blend because it reduces emissions as well. you being in california, im sure you have put plenty of ethanol blend gas in your car and not realized it. they are required to tell you about it, which usually means there is a little sticker on the pump about the size of a business card that states that the fuel may contain ethanol.
ryan1994mustang is offline
Old 07-31-2009, 01:52 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
10% Ethanol is not going to do anything to your engine. Look at all the guys who convert their cars to E85 (85% ethanol), it mostly guys who run blowers or turbos as E85 has about a 105 octane rating. BTW "octnane" in and of itself does not make more power in a stock to lightly modded engine. You really need forced induction or high (over 11.0:1 IMO) compression.
JD1969 is offline
Old 07-31-2009, 02:01 PM
Derf00
Gentleman's Relish
Derf00's Avatar
And I spend $20,
I avoid ARCo stations here in AZ for the fact they have a Surcharge of like $0.75 if you use a debit card to pay for gas instead of CASH. If you take that into account when you fill up, their "cheaper" gas can actually cost you more per gallon than the Chevron accross the street!
Derf00 is offline
Old 07-31-2009, 10:01 PM
USMC1775
USMC1775's Avatar
Arco has a lot of water in their gas too. Next time youre there, put some in a clear container and examine it...
USMC1775 is offline
Old 08-01-2009, 01:49 AM
ckosiek
ckosiek's Avatar
I haven't seen any Arco stations on the East coast, but everything is 10% Ethanol where I live...
ckosiek is offline
Old 08-01-2009, 10:45 AM
KeneticEnergy
KeneticEnergy's Avatar
say no to arco. my vehicles in the past have always liked chevron
KeneticEnergy is offline
Old 08-01-2009, 01:24 PM
geryogery
geryogery's Avatar
So you have actually been able to see the water? Wow!
I have read posts of people who claim that they cut costs by not maintaining their tanks properly which can lead to dirty gas and moisture getting into the gas.
4cylinderplus2
10-09-2020 07:45 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Quick Reply: SO WHO HERE USES ARCO GAS?
