Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-08-2009, 11:15 AM   #1
david LaB
Vehicle: 1967 mustang coupe
Unhappy Help 67 Mustang holly Carb Popping
Anyone..Ideas. My 67 mustang idles great accelerates great when in park but when I put it in gear and drive it makes popping sounds and the ride shutters or the movement of the vehile hesitates with the popping.
I took the carb off again and took it to the rebuiler. They tested it and stated it is fine. When I took off the fuel line off the carb it was pressurized and air forced out of it when i took it off.
289 engine ? v8 ? stock
THINGS Iv'e done.
Profeesionall re buillt holly carb ?2 barrell
new fuel pump
new plugs
timed the vehicle
new points.
new gas tank and purged the lines
I am checking for air leaks in the gas lines nnow
Any Ideas?
Thanks
Dave L.
david LaB is offline   Reply With Quote
Old 08-08-2009, 11:42 AM   #2
a_penquin
1998 Ford Mustang
Vehicle: 1998 Ford Mustang GT
Send a message via AIM to a_penquin Send a message via MSN to a_penquin Send a message via Yahoo to a_penquin Send a message via Skype™ to a_penquin
Check your point gap, advance and ignition timing. Almost sounds like the vacuum advance may be sticking, or the timing is slightly off.
__________________
98 4.6 SOHC GT
MSD coil packs, Headman street headers, BBK X-pipe w/cats, Cherry Bomb vortex cat back, ZOOM clutch, Auto Meter 3 pillar w/oil press, water temp, and volt gauges, Alpine head unit. work still in progress.
a_penquin is offline   Reply With Quote
Old 08-09-2009, 02:30 PM   #3
david LaB
Angry 1967 mustang carb still popping
Adjusted again the timing, points and checked fuel lines for ar leaks and it's still popping in drive when I accelerate. It still idles fine and accelerates fine when in neutral.
Any ideas?
Old 08-09-2009, 02:58 PM   #4
a_penquin
1998 Ford Mustang
did you adjust the carb right, one of the needles might have worn a little, gummed up some or wiggled loose
__________________
98 4.6 SOHC GT
Old 08-10-2009, 08:13 PM   #5
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
Vehicle: 78 Ford Fairmont
Sometimes a bad coil or spark plug will do the same thing.
__________________
Worlds fastest 357 c.i.d.,With one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior,1983 Crimson Cat,Mercury Capri RS in my garage.(8.31 166)Under Reconstruction!
1978 Ford Fairmont Stationwagon,351 Windsor,Turbo-350,8.8 31 spline axles,steel spool,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Track locator,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.470,440@wheel
wagontrain is offline   Reply With Quote
50, 67, advance, carb, carburetor, cyl, fairmont, ford, gap, gas, holley, leaking, mustang, mustang carb problems, point, popping, vacuum
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
