Sponsored by:
Sponsored by: DashLynx
15" Cragers on 99GT
Old 07-06-2005, 09:36 PM
72MachOne99GT
2010 Blue Ball Award Recipient
72MachOne99GT's Avatar
Default 15" Cragers on 99GT
Okay, in effort to be more unique, and to save money, as well as look more old muscle car-like, i am looking for a set up that involves 15" wheels on my 99GT, at stock height, (where it is likely to stay)
Does ANYONE have a similar set up to this? I am hoping for either someone who has this already, or knows enough about old tire ratings and sizes.. namely 15x7/8/10/12.
I want to know what they would compare to with modern numbers, ie: 275 & 315's
( i was already told to go with a 26" tire to prevent from needing to recal the speedo)
here is what im looking at
Back:
Cragar 08/61 Series S/S Wheel
Size: 15' x 10'
Bolt Circle: 5 x 4-1/2'
Rear Spacing: 4-1/4'
OR
Size: 15' x 12'
Rear Spacing: 4-1/2'
Front:
Size: 15' x 7'
Rear Spacing: 4-1/8'
OR
Size: 15' x 8'
heres what it looks like
[IMG]local://upfiles/11183/0ED52E303DCA4430A8BA03A7884D6363.jpg[/IMG]
72MachOne99GT is offline
Old 07-06-2005, 09:43 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Default RE: 15" Cragers on 99GT
IMO it will look terrible but if you like it thats all that matters. You might also want to double check that the rim will clear the brake caliper, there is a good chance it will hit.
JD1969 is offline
Old 07-06-2005, 09:50 PM
72MachOne99GT
I like the way that the fat tire looks on newer (and older cars)
like the pic of code03's wifes car... the fatter tire on a normal looking mustang
but back on course,, did you mean that the wheel, since only a 15" , 'could' have trouble clearing the caliper, as in it woudl rub the inside of the rim?
i thnk thats what you mean is it not?
thanks
Old 07-06-2005, 09:53 PM
closer9
closer9's Avatar
I think it will look great, and may do something similar. I've been thinking the old slot style aluminums, Torque Thrust II's or Cragar SS/SS II's with RWL BF Radial T/A's...
Look in the 4.6L forum at code3Gt's 2 cars...
Oh, and yes, you definately need to make sure they will clear your brakes...
closer9 is offline
Old 07-06-2005, 10:11 PM
mkspeed26
mkspeed26's Avatar
only 15s? 15s are tiny
mkspeed26 is offline
Old 07-06-2005, 10:27 PM
JD1969
JD1969's Avatar
ORIGINAL: 72MachOne99GT
thanks
Yes that is what I meant. I like a 15 inch on a car with slicks and skinnys, but to each his own.
JD1969 is offline
Old 07-06-2005, 11:30 PM
72MachOne99GT
ORIGINAL: mkspeed26
they arent tiny, stock are 17...lol... well, it depends on your definition suppose
15's are what came on everything old.. which is what i like
I already pm'd back and forth a bunch with code03gt, and i dont think he said anything about having trouble clearing the breaks and such. I might ask him if he doesnt pop in here on his own
so jd, assuming that all fits around the breaks and all,, is there any way other than going out and measuring my current tires, to be able to tell how big of tires i woudl need for each size of rim, wheter i go 7 or 8 in front, and 10 or 12 in back?
Old 07-07-2005, 12:37 AM
fordguy17
fordguy17's Avatar
i got 15's on mine...
[IMG][/IMG]
[IMG][/IMG]
fordguy17 is offline
Old 07-07-2005, 02:12 AM
closer9
closer9's Avatar
ORIGINAL: mkspeed26
Real easy. Just sit down with your calculator and figure the stock size, and each tire you're thinking about...
245/45/17 is stock... 245 is the tread width in mm, 45 is the sidewall height as a percentage of the tread width, and 17 is the wheel diameter in inches... so, to figure overall outer diameter of the stockers, it would just be...
245mm*.45*2 (=220.5mm) + 17"*25.4 (=431.8mm) = 652.3mm so, just find a tire with a close OD...
closer9 is offline
Old 07-07-2005, 02:50 AM
UhadMEatGT
UhadMEatGT's Avatar
I would go with the Torque thrust 2 with some BFGoodrich radial T/A with the white letters facing out, for the muscle car look. I think it could look cool. What really sets that look off is lowering it 1.5"-2". Good luck and let us see the pics. At least your not a sheep!
UhadMEatGT is offline
Quick Reply: 15" Cragers on 99GT
