Sponsored by:
Sponsored by: DashLynx
Starting car after few years of sitting...tips?
Old 07-09-2005, 12:41 AM
ryan0007
ryan0007's Avatar
Default RE: Starting car after few years of sitting...tips?
I totally agree, complete set-up. 86gt5.0HO your from listowel? Thats not very far from me, in the winter im there snowmobiling a lot.
Ryan
ryan0007 is offline
Old 07-11-2005, 03:17 PM
Deannostang
Deannostang's Avatar
Change oil and fuel. New oil and fuel filters also. Replace distributor cap and install new points & plugs. Be sure battery is strong. Disconnect the coil wire so the engine will not start. Turn ignition key on and off a few times. This will pump up oil into your engine without worrying about starting a "dry" engine. Turn over a few more times for good measure. Reconnect the coil wire and start engine normally. After sitting for so long there may literally be no oil whatsoever left in the upper areas of the block and heads. That is why you must first turn your engine over with the coil wire disconnected. Good luck!
Deannostang is offline
Old 07-11-2005, 05:03 PM
99saleen351r
99saleen351r's Avatar
ORIGINAL: 86gt5.0HO
That american hotrod crazyhorse stang was totally set-up. A car that has sat in a barn for that long will never start right up. When they showed it on the truck the rotors were nice and shiney. A car that had sat that long would not have shiney rotors.
It doesnt really matter how long its been sitting it doent nessasarily mean the rotors are going to rust all depends on the climate its in.I do agree that could be a setup but why would they drag it out then try to start it?I have a car thats been sitting for 6 years and the rotors are still shiny and its outside
99saleen351r is offline
Old 07-11-2005, 09:40 PM
ryan0007
ryan0007's Avatar
Thanks for the tips guys, and i did throw some extra oil in the cylinders/valve covers. She runs like a charm. Only thing is it wont run without a battery...is this normal? Like ill have it running and ill pull the ground on the bat and it will die, its like it needs to have a completed circuit to run. Maybe this is normal i dunno.
Thanks,
Ryan
ryan0007 is offline
Old 07-12-2005, 12:31 AM
white_snake
white_snake's Avatar
ya im sure that is normal. iv had cars die on me because the alt quit and drained all the juice from battery, then quit.
white_snake is offline
Old 07-12-2005, 12:38 AM
ryan0007
ryan0007's Avatar
I always thought the alternator generated enough juice to keep it running, my alt should be in awesome shape as i remember i had it rebuilt.
Ryan
ryan0007 is offline
djbigskrilla
09-20-2022 01:04 AM
KEM Motorworks
08-14-2015 10:13 PM
drumhedd2005
08-13-2015 09:59 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Starting car after few years of sitting...tips?
