Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-03-2009, 10:48 PM   #1
slplsnphx
Vehicle: 2000 ford mustang 3.8L
Default please help. keys locked in car, battery dead!
i have a '00 mustang 3.8L and i made the mistake of letting a friend borrow it. he wasted no time at all locking the only key in the car... in the ignition... in the on position!
now the battery is dead, so hitting the unlock button won't do any good. can someone tell me if the door will unlock if i can hook the door handle and pull it? or if anyone has a better idea.....
slplsnphx is offline   Reply With Quote
Old 09-03-2009, 11:03 PM   #2
Monkeyleg
Vehicle: 2007 GT
If you don't know how to slip one of those thin bars into the door to unlock it, now probably isn't the time to learn.
Police officers often know the trick and have the metal bars to do it. You could also call a locksmith. He'd probably know how to jimmy the lock.
If you're feeling adventurous, check out these videos: http://www.youtube.com/view_play_lis...tang+door+lock
__________________
Dick
Monkeyleg is offline   Reply With Quote
Old 09-03-2009, 11:07 PM   #3
slplsnphx
thanks for the quick reply. i will check out the videos you mentioned. but i still would like to know: with the door locked, if you pull the door handle (inside), does it unlock? i know some cars would do that but strangely enough i have know idea if my mustang works that way.
Old 09-04-2009, 12:31 AM   #4
ryan1994mustang
Send a message via AIM to ryan1994mustang
my 94 will unlock from the inside by pulling the handle. id assume your 2000 would as well.
__________________
1994 Mustang GT, just a few minor appearance mods, engine mostly stock (for now)
ryan1994mustang is offline   Reply With Quote
Old 09-04-2009, 12:33 AM   #5
slplsnphx
thanks for the help. anyone else that has a '00, can you verify?
Old 09-04-2009, 06:25 AM   #6
Fink
1999 Ford Mustang
Fink's Avatar
Vehicle: 1999 Ford Mustang
I have a 99 and yes they unlock from the inside. The easiest way to get into a Mustang is to pull the door handle up a little bit so you can see a small square hole under it. Cut a metal coat hanger about 10" long and curl one end.
Put the curled end into the door through the square hole. Feel around until you hook the rod for the door lock. When you have it hooked, pull on the coat hanger and push up.
It is a little easier if you wrap hockey tape, sticky side out, on the curled end.
Hope this helps. If it doesnt, call a professional.
__________________
Mods:
MAC LT's & O/R H, ROUSH Side Exhaust, GT Rear Sway, SCT X3, Auburn LSD w/ 3.27's
Waiting:
Cobra Brake Kit Front and Rear, KYB GR-2 Shocks/Struts (waiting on C/C plates)
Quote:
Originally Posted by brian1570 View Post
now RS is gonna come in here and start sh!tting on his keyboard again.
Fink is offline   Reply With Quote
Old 09-04-2009, 08:04 AM   #7
GreyStang
Just get your car unlocked by a professional auto service company, or maybe even tow truck operators could do it for you after you've proven to them it is YOUR car
Tell them to bill you for the work & give the bill to your idiot friend. Why dick around trying to unlock the car yourself & maybe risk scratching paint or damaging the lock mechanism?
__________________
2002 GT convertible
1999 Yamaha 1100 Virago
GreyStang is offline   Reply With Quote
Old 09-04-2009, 11:04 AM   #8
BlueBloodedPony
Forum Sn!tch
2000 Ford Mustang
BlueBloodedPony's Avatar
Vehicle: 00 Stang shooting a full clip
Lesson learned, always have a spare key. I don't know if you could also try pulling the outer belt strip off and having access down the door that way or not. That way at least you won't scratch you glass with the hanger.
__________________
2000 Ford Mustang GT; Accufab 75mm TB&P; JLT cai; SLP lm2'S; Summit O/R H; Sniper tuned; 4:10's. SFC's, Tokico HP Series Shocks & Struts, H&R Super Sport Springs, MM Caster Camber Plates, UCA's & LCA's all are here; To be installed shortly
BlueBloodedPony is offline   Reply With Quote
05, 2000, 2008, battery, car, coat, dead, ford, hanger, ignition, key, keys, locked, mustang, unlock
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
