TKO500
RE: TKO500
the trick with it is shift into first then into first.......reverse is is an odd ball synchro i guess??? you are not the only one..alot of us
thought there was something wrong with it..
RE: TKO500
No, it's not that.
I knew that about my T5.
It never ground when trying to put it in gear, just wouldnt go into gear so easy.
This grinds when the clutch is to the floor and trying to stick it in gear.
Edit: Just reverse though.
I have my clutch adjusted to about half pedal for full engagement.
RE: TKO500
damn???that's about where my peddle engages.....mine only grinded if i went straight into reverse while parked....i have had it where
all gears got really notchy.....funny now (not then)LOL!....i about pooped a brick when it did that....that was 5000mi. ago though..
have you called and ask tremmec yet??
RE: TKO500
ORIGINAL: prostockpuds
the real reason it grinds is because there are no synchro's in reverse and if u put it in first before putting it in reverse it wont do it
RE: TKO500
Holy Noobs not know what there talikin about......If you have to put" I think" after you answer a question you shouldnt be answering.I not trying to be mean but why answer if you dont know what you talkin about?People believe you and you give wrong answers.Trannys do have sycros in reverse and its not bad to downshift to first?????
travisl1213
02-10-2008 02:24 PM
sarpicaste
Mustang Videos
10-18-2006 05:33 AM
