Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-17-2009, 12:49 PM   #1
blue95stang
Vehicle: 1995
Default Rear end gear noise.
I have an 02 GT. Its has 3.73 gears, speed cal, exhaust, intake, and a pro 5.0 short throw. It has been making a whining noise around 5th gear or going about 45mph. I was told just to listen and make sure the noise doesnt get worse. But what should I do?
blue95stang is offline   Reply With Quote
Old 09-17-2009, 12:57 PM   #2
silverscmustang
silverscmustang's Avatar
Vehicle: Awaiting next Ford :)
you could try having the pinion adjusted but id say that if youve been driving on these gears for a while, whatevers making it make that noise is worn into the gears, youll probably need new ones to get rid of the noise
__________________
Previous Cars:
2005 Mustang V6
2005 Mustang GT
Current:
2007 Roush Nitemare #58 out of 100
silverscmustang is offline   Reply With Quote
Old 09-17-2009, 03:01 PM   #3
BlueBloodedPony
Forum Sn!tch
2000 Ford Mustang
BlueBloodedPony's Avatar
Vehicle: 00 Stang shooting a full clip
May need a readjustment since it is gear whine, but depending on miles on the gears, you might want to consider just buying another new set and installing them. Would hate to pay for a repair, only to find out it is still doing it.
__________________
2000 Ford Mustang GT; Accufab 75mm TB&P; JLT cai; SLP lm2'S; Summit O/R H; Sniper tuned; 4:10's. SFC's, Tokico HP Series Shocks & Struts, H&R Super Sport Springs, MM Caster Camber Plates, UCA's & LCA's all are here; To be installed shortly
Quote:
Originally Posted by Rdot9 View Post
...mmmm nice and thick ftw...
BlueBloodedPony is offline   Reply With Quote
Old 09-18-2009, 04:23 AM   #4
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Could also be a bearing whine in which case you would need to rebuild it. Unless you know what you are doing and have access to things like a bearing splitter, 20 ton press, and an impact gun capable of crushing the sleeve, replacing bearings in the rear diff is best left up to someone that does.
Also, rearend gears that are whining and already have an established wear pattern are almost impossible to setup so that the whining goes away.
hiboostwoody is offline   Reply With Quote
2000, 2005, 2006, 2007, density, differential, end, ford, gear, gears, gt, mustang, noise, racing, rear
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
