Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-26-2009, 10:05 PM   #1
mustangcat
Hair Ballz
mustangcat's Avatar
Vehicle: 2000 Mustang GT
Default Brake Booster - Difficult?
Ok. I'm helping a girl with her 1998 GMC Sierra truck.
Her brake pedal is extremely stiff, almost too hard to push. She nearly wrecked the other day when the brake pedal randomly did that.
Sounds like the brake booster right?
Are they hard to replace?
My mechanical ability is probably around "medium-low"
THANKS!
__________________
mustangcat is online now   Reply With Quote
Old 09-26-2009, 10:16 PM   #2
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Sounds like your daignoses is probably right. The booster replacement isn't too bad. The only thing that sucks is that you have to disconnect the operating rod from the brake pedal under the dash so that requires you to be in a contorted upside down position while you take the retaining clip off. You probably won't even have to remove the brake lines from the master cylinder so you won't have to bleed the whole system. I did one on a late 90's Yukon recently and I just took the mounting nuts off and pulled the master out of the way with the lines still attached. Just be sure not to kink them. Also, be absolutely sure you get the brake light switch reattached properly to the pedal (it attached to the same place as the booster operating rod) as the brake switch controls cruise control and transmission torque converter clutch functions.
hiboostwoody is offline   Reply With Quote
1998, 68, booster, brake, brakes, control, cruise, dash, early, gt, hard, mustang, push, removal, removing, sn95
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
