I installed my exhaust maybe a month ago, but for some reason it's hanging too low now, I checked all the bolts they are tight any ideas on how to fix this?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
what part is hanging down the front or the back, i had to put a jack under the h-pipe and tighten it back up to get it to stay higher.
__________________ 02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
if your tips are hanging low loosen the h-pipe and jack the tips past where you want them by about .5" and then tighten the h-pipe and then remove the jacks
Sorry I didn't specify it's from the x pipe back that's hanging low. What I've done is held the x pipe higher tighten the bolts again bust most of them were already tight, which didn't seem to help out much.
Great post! It's very nice and userful. Thank you so much for your post.
