Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-28-2009, 01:48 PM   #1
jr0c1
Vehicle: 1994,ford,mustang
Default 1994 Stand Experts Only! (help)
ok!
1) problem: Check Engine light is On. Engine is not Gaining Power when Driveing and Wont Pass 2nd Gear or Over 80mph Whats Wrong ?
Clue: got an Diagnostic and it said Left side 1 On lean! any answers for that ?
2) problem: im hearing Rattling on the Bottom of the Car and all of a Sudden my Break Lights came on. is that Due to the Rattling . it only Happens when I bREAK... BUT WHEN I DRIVE I CAN HEAR IT A LITTLE. LIKE MY EXHAUST IS lOOSE OR SOMETHING
3) pRoblem . does any one know what size screw goes in side an 1994 door panel so ican buy em because my Door Panel Keeps Falling off due to no Screws
jr0c1 is offline   Reply With Quote
Old 10-28-2009, 04:26 PM   #2
dreamer1uk
Vehicle: 1993 Mustang Convertible 2.3 N/A
Send a message via Yahoo to dreamer1uk
Hi
That code (im guessing a P0171) is telling you the O2 sensor is registering too much air left over after combustion. That could be a possible faulty o2 sensor (can be checked with a DVOM) or you have a vacuum leak on that side of the engine.
As for the brakes, do a physical inspection. If the brake light is on, that could down to low brake fluid or a inbalance in the hydraulic system of the brake lines. Are the pads and rotors grinding?
So auto shops will offer a free brake inspection. Just an FYI.
Hope this helps.
__________________
1993 2.3 Mustang Convertible
dreamer1uk is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
