Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-31-2009, 01:52 PM   #1
txbubba
Vehicle: 1966 ford 289
Default 289 rebuild ?
I am looking at rebuilding my 1966 289. If the block has already been bored out to the limit can I use a 302 block with my 289 intake, distributor, Etc.
Thanks
txbubba is offline   Reply With Quote
Old 10-31-2009, 02:22 PM   #2
capri man
capri man's Avatar
Vehicle: 73 mach 1, 81 capri
yes everything should just bolt up.
__________________
73 Mach 1 riding around, drinking car
81 capri drag car
racing is real, everything else is just a game!!
capri man is offline   Reply With Quote
Old 10-31-2009, 02:23 PM   #3
capri man
capri man's Avatar
btw welcome to the site. you can get a lot of good info here. do not be afraid to ask anything.
__________________
81 capri drag car
Old 10-31-2009, 05:55 PM   #4
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Absolutely EVERYTHING, at least external, will be the same. The only problem you could potentially run into is if your 289 is an early 5 bolt bellhousing block then you would have to use all the 5 bolt bellhousing stuff but if your block is a '66 this shouldn't be an issue. It should be the more common 6 bolt bellhousing block.
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
hiboostwoody is offline   Reply With Quote
289, rebuilding
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
