I have a '66 Mustang with a 2barrel 289 automatic. In park i have no trouble revving the engine. However, when put in drive and if i press the throttle and quickly let off my car stalls. There are no gasket leaks, however, im blowing smoke out of the breather meaning my rings aren't in great shape. Does this have anything to do with stalling or is it something else? This gives me a lot of trouble in an emergency situation.
Thank you.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
When you punch the gas does black smoke come out of the tail pipe? Or if you go to WOT and stay in it does the car fall on it's face and then go? And how much smoke is coming out of the breather, and are you running a PCV system?
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
No black smoke the car runs good besides the rings. Its smoke quite a bit from the breather but now that i think of it the car did stall before the rings problem. I am running a PCV system on the passenger side but the driver side vavle cover has a breather.
Is it only if you let off quickly, or does it bog when you stay in the throttle as well?
__________________
__________________
Sounds like you need a carb rebuild. It's easy to get a carb to run good in park or neutral. The hard park is keeping a good balance in drive or reverse.
