Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 06:57 AM   #1
duder69
Vehicle: 1995 mustang gt 5.0
Default k&n vs. c.a.i.
greetings, i have a 95 5.0 5 speed. i've learned that instead of cold air intake, i can just put in k&n filter inplace of o.e.m. filter and take silencer off and it will be same as c.a.i
., is it true
duder69 is offline   Reply With Quote
Old 11-03-2009, 07:14 AM   #2
GreyStang
Yep it's true. In some cases doing that is actually better for performace than adding a full CAI kit, as many kits are really cheap, leak air, & can fall apart. Also kits using a metal tube might look neat-o but can actually cause intake air to heat up because of heat transfer thru the metal tube..
__________________
2002 GT convertible
1999 Yamaha 1100 Virago
GreyStang is offline   Reply With Quote
Old 11-04-2009, 04:22 PM   #3
nba1341
Vehicle: 1965 mustang fastback
how do you take the silencer off and what is this silencers functional purpose
__________________
1965 mustang fastback 302
nba1341 is offline   Reply With Quote
Old 11-05-2009, 11:12 AM   #4
Matt's 95 Stang
Matt's 95 Stang's Avatar
Vehicle: 1995, 3.8, Silver Coupe
The silencer is the the mesh screen infront of the MAF. You can just add a good filter to the OEM intake, take the screen out and save yourself the $70 or so dollars you would spend for a full on CAI.
Matthew
__________________
3.8L '95 Coupe -
Mach 1 brake kit and chin spoiler, GT foglights, CAI, '99 GT 17's, true duel, GT rear sway and strut tower brace bar, Steeda Tri Axe, Aluminum grill, 05' shift knob, limo tint.
Matt's 95 Stang is offline   Reply With Quote
Old 11-05-2009, 12:44 PM   #5
GreyStang
NO! On NewEdge stangs the silencer is that cone shaped tube that juts into the side fender from the side of the air cleaner housing. It's NOT the screen in front of the MAF.
The silencers job is to quiet down the intake air sound. Unfortunately it also really restricts the intake airflow, and besides a REAL car lover LIKES the air intake moan sound!
__________________
2002 GT convertible
Old 11-05-2009, 12:50 PM   #6
RogerDodger1
Vehicle: 1989 Piece of Junk
Quote:
In many cars that MAF screen has a heated wire that is part of the proper functioning of the MAF. Removing it will screw everything up. Think long and hard before removing parts that a highly educated automotive engineer put there.
RogerDodger1 is offline   Reply With Quote
cai, kn
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
