Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 04:51 AM   #1
demon91887
Vehicle: 1979 ford mustang
Angry No Spark
ok i just recently bought a 79 hatch 5.0. when i bought it i knew it had problems with getting fuel to motor so dropped tank flushed out blew lines then ran a while but eventually killed bc so much rust in tank it reclogged the lines. so pushed home and dropped tank again. i brought the tank to a radiator shop and got them to boil it out and recondition it. got home and put back on. now that it was clean filled up tank and would crank but just wouldnt start..... so did complete full tune up. new wires, plugs, rotor, distributer, distribuer cap and coil. still nothing. checked fuel lines at motor and has plenty. so pulled out spark plug and tried cranking to see if had spark and had none. so i pulled coil wire put screw driver held 1/4 off motor to see if had spark and nothing. borrowed a friends test lite and have does power to both sides of coil. didnt bother checking ignition fuse bc i would assume since it is trying to crank it wouldnt be that. so if anyone knows anything i would really appreciate the help
demon91887 is offline   Reply With Quote
Old 11-08-2009, 05:40 AM   #2
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
If you have power to both sides of the coil but no spark out of the coil, it has to be a bad coil.
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
hiboostwoody is offline   Reply With Quote
Old 11-09-2009, 03:09 AM   #3
demon91887
yeah but i have put a brand new coil in before it ran out of gas and cleaned the tank which might have been a couple weeks ago then after that i put a coil in from out of another car that was running with it in. to the point of was running killed took off put on my car and still nothing
Old 11-09-2009, 10:38 PM   #4
chronos
chronos's Avatar
Vehicle: 09, Ford, Mustang
I don't know much about Ford ignition systems in your model year, but I'll throw out a couple of ideas. On Dodges it's called the Crank Positioning Sensor and when that goes out you get no spark. It's a separate device from the coil. In the older GM cars it was a module at the base of the distributer that would also control the spark. Don't remember what that was called, but when it went bad, you got no spark. Try and figure out what Ford has that would do the same thing and check that out.
__________________
chronos is offline   Reply With Quote
23, mustang, spark
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
