I'm getting ready to put my mustang in the garage for the winter. I was told by several people that I should put the car up on jack stands so that the tires don't get flat spots on them from sitting in the same place all winter. Is this really necessary, or is it just a load of bs?
Thanks in advance,
C.O
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Thanks in advance,
C.O
Flat spotting can occur and it wouldn't hurt to be safe. Tires aren't cheap anymore.
Thanks for the answer! I'll try to get it up on jackstands, but if that isn't possible, (not much room left in my garage) I'll inflate them to 45 psi and hope for the best.
I agree with not worrying about flat spots but also for the reason. I think a car is happier sitting on it's tires. So if it all all bothers you. Find some junker rims/tires to store the car on.
__________________
65 Belevedere
69 Super Bee
87 Ram
93 Mustang
00 Park Avenue
The flat spot thing was more for cars with bias-ply tires. Steel belted radials don't have that problem. Be sure to put some Sta-bil in your gas and run it for a bit before you put it up. That'll keep your gas from turning to syrup and contaminating your entire fuel system.
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
If you're nervous about flat spots & R too lazy to jack up the car,.. just leave a couple feet clearance in front of the stored car. Roll the car forward or backward a few feet every couple weeks
if ur not gonna jack it atleast park it on sum carpets that way the concrete isnt touching the rubber and sucking the moisture out of the tires (no scientific proof just wat my dad has always done)
Moisture from the concrete can be a rust problem, although I don't know it being a problem for tires. Could be.
I was taught to put a layer of plastic sheeting on the floor, then a layer of plywood, then another layer of plastic, all as a vapor barrier.
